How much of the thread should show on the adjustor cable....
(In Topic #131509)
Paul
If its not behaving as it should, then its probably a different problem like one or more of the fittings on the clutch cable is missing or the bulkhead is flexing (too much). Another thing I've noticed is, the clutch feel can be improved if the cable is secured (eg with cable ties to any handy brackets etc) so it can't move around too much as it takes up tension.
There's a possibility its a cracked release bearing/actuating lever too - but that's for another day!
lots of info on cable setup, pushrod, finger, bearing etc here:
Welcome to BrokeVW.com
the bulkhead may be flexing due to damage, or it may just be your clutch is too old and heavy which is putting strain on it. 1st thing to do is check the bulkhead, if its cracked or rusty get the repair plate from GSF and stick it on. Ive seen people use 2 plates to beef it up even more
