How low can you go?
(In Topic #143217)
How low can you go?
ride was awful but i could see some person being ok with that. the only thing that i stuggled with was the sump.
get a shorter sump and then keep it at around 80mm and it will be so much nicer.
For suspension lowering (which isn't the same as overall lowering - which also relates to tyre size) a good place is centre of wheel to top of wheelarch. Do a search and you will find the measurement for standard height car, so you can work out easily how much you've lowered suspension by.
