Hand brake light - stays on all time.
(In Topic #76338)
What I have done so far to troubleshoot.
1. I've checked the switch itself with another one - all fine.
2. I've taken the one cable off the hand brake switch - good connection and switch itself is fine as well - when I do take cable off the hand brake switch light stays on.
3. The brake fluid is a max level too.
Could this be a earth issue?
Anyone had this issue before and how to fit?
thanks Si
Remove the brake master cylinder cap and make sure the switch in the top is working by bridging the wires then pull the plunger gently down .
This will prove the cylinder switch is not to blame .
If you have a later Cabriolet ? does it have more than 1 brake warning switch or warning system ?
Hope it helps ……..
