gearbox question
(In Topic #104178)
Member 125 - 2005
gearbox question
i have a mk1 gearbox which i know is good and both plates turn in the same direction ? would it be posibble to turn by hand if in gear ?
and a mk2 g60 gearbox which ends rotate in opposite direction when turned.
seem to remember being told along time ago that if they spin in the opposite directions the gearbox has a lsd fitted and because one side is being spun it alters the drive to the otherside ? so am i jammy and bought a gearbox with a lsd without realising ? are there any visible signs of a slip diff being fitted.
Member 125 - 2005
The term LSD is used to mean various types of diff, it actually refers to a Limited Slip Differential, you can also get TBD (Torque Biasing Differentials from Quaife or Peloquin) as well as various 'locking' differentials (like H'Or)
It is normal with a production differential for the drive flanges to rotate in opposite directions if one is turned. But remember after about 1982 (ish) mk1 Golfs were fitted with 'mini slip' differentials were the diff side gears are preloaded with large springs to make them behave a little more like a locking diff. When these diffs are in very good condition and still tight it is possible for both flanges to rotate in the same direction…
Member 125 - 2005
Member 125 - 2005
because theyre diffs…… :roll:
abfmk1 said
Sorry i know no more, apart from i thought i knew where i had read this and found the article and all it said was later box,s had the springs but no date. So if the g60 box is later which it must be then maybe no lsd.
The later type boxes are easy to identify by looking at the output flanges, if there is a green metal sleeve between the flange and the diff casing it is a mini slip (FM onwards). If not, then its an early box (FH etc)..
If its an early box (no green sleeves) AND the flanges rotate in the same direction when one is turned then it DOES have a aftermarket diff..
Member 125 - 2005
Member 125 - 2005
Stage 4 usually indicates Jabbasports work, how long ago was it done?
That setup, with a good exhaust will get you 190bhp or there abouts (thats real power, not forum power) is the head and cam stock? swapping to a Piper 285 with a stock head and that charger will give the best all round package, especially in a mk1…
mk1jim said
8O :twisted: don't think i'll get enough private airfield,
Belgiums Jabbeke Highway is your friend…. :twisted:
Member 125 - 2005
Member 125 - 2005
I'm trying to use this with the ABF conversion too
Thanks in advance.
www.Prept.co.uk
