Gearbox crunch when cold
(In Topic #141087)
When I first run my Cabby from cold, it crunches from first to second unless I let the revs drop real low. This does;t happen at any other gear change, and cures when the engine is warm. Any ideas? Cheers.
Pretty standard on a 020 VW gearbox. You can try and replace the oil with some semi-synth 75w90 to see if that helps.
