Gear oil change/slipping clutch
(In Topic #106484)
Ever since my clutch has been slipping, so I think its got oil over the clutch as its too much of a coincidence that the clutch went a few minutes after doing the oil.
I would assume its the seal for the push rod thats gone and probably why there wasnt much oil in it - which brings me to my question - how difficult is it to change the seal?
obviously it will be a gearbox out job which doesnt bother me too much (although I could do without it in this weather!), but is it a complete strip down of the box? If so might just find a new box as its quite crunchy going up and down into 2nd & 1st
Just a thought - did you definitely put the oil in the speedo hole? There's a hole in the gearbox casing for setting the spark timing with (goes through to the flywheel & clutch)…
Stop me if you already know what I'm talking about!
HTH
Rich
Get the pushrod bearing too as wear in this causes wear in the seal. Think about changing the rear crankshaft seal while the box is off too…
Can clean the clutch with coke if there is plenty of life left in it.
Does it have to be coke? or will pepsi do just as well?!
Cheers guys, looks like I have a fun weekend coming up soon!
Member 125 - 2005
if your in disbelief about the coke. Try sticking a dirty penny (or a 2 p if your loaded But Credit crunch and all) in some coke over night.
Next morning Bling coin…
Magic…..
get the bigger hammer. it always makes things better…..
Highland Regional host
rossirvine said
cheers jim, might need the red ones box the way its going this week!! - when it gets warm, bout 20mile into the trek to work its started tonight not wanting to change down at all from 5th - really having to bang it in hard. but its fine again when I came to it after work, then same again around 20 mile in, having to bang it into gears…..strange….
That's not symptoms of a slipping clutch!
cedar said
I could be wrong but I think the oil causes the friction disc to stick to the pressure plate.
yep wrong
oil will make it slip badly
try adjusting the clucth and see if the gear change is any easier
if you slacken the cable it may stop slipping
Crunching into gears is probably down to the adjustment but could be the symptom of another issue with the cable, eg bulkhead flexing where the clutch cable goes in, fittings missing, or the cable otherwise loose.
