Gear change remote query
(In Topic #99249)
Gear change remote decided to pack in this morning and have spent an evening trying to sort a way round it but to no avail
My main question being, where can I get a new gear change remote from for a 1600 GTI? Is it a dealer only part?
Also how much would I be looking to pay?
Many thanks
Dan
<a href="Pictures by defcat - Photobucket"><img src="
It's "<b>GTI</b>" <i>not</i> "GTi"
http://i28.photobucket.com/albums/c232/defcat/mk1gocsig.jpg" border="0" alt="Photobucket"></a>It's "<b>GTI</b>" <i>not</i> "GTi"
You know where the gearstick comes from and you have a series of springs and bushes in a contained unit, I mean that.
I'll see if i can get a picture of some sort.
They're the best part of ?40 but at least you'll know it'll be correct. I've done a few of these on the vans that me and my brother own (same part) and once you get the hang of squeezing the spring and putting the plastic parts in the housing you'll get it done in no time.
Yradave says relax.
07792646786
07792646786
:dontknow:
CAMPAIGN-HELIOS BLUE-POSSIBLY SEEN IT ON CHRIS BARRIES(RIMMER IN RED DWARF) MASSIVE SPEED PROGRAMME?!!!
Yradave says relax.
07792646786
07792646786
Thanks a lot
Also will probably go GSF, they may have one for a bit less cash although nothing is listed on their website.
Bus trip to town tomorrow then 8O
Cheers!
Deejay said
there's something up with it which is making the stick drop and not engage gears.
:dontknow:
It could just be the spring retaining ring has come loose, follow me on this:
Above the pivot ball assembly there's a big spring, this holds the gearstick up and is what you push against to put the car into reverse.
It is held in at the top by a small metal ring that goes around the gearstick and is fairly snug to the stic itself but not too much wider than the spring.
This is held onto the gearstick by a small screw on the side of the ring that screws into a divot in the stick itself. if this has come loose it will make your gearstick drop and might cause you problems. To get it in you'll have to lift the gearstick up and push the top spring down.
Yradave says relax.
07792646786
07792646786
As far as I'm aware GSF will only do a bush kit and shift rods and don't actually do the bits for the gear stick itself. :dontknow:
Yradave says relax.
07792646786
07792646786
yradave said
:dontknow:
Hmm I know what you're talking about it's just I don't recall seeing a screw.
On top of the spring there's the circlip right? And thats all I can see above the spring to keep it in place :dontknow:
Looks like that's mistake number two. No screw on a mk1, only on vans.
Sorry again.
Basically the spring needs to be under pressure to push the gearlever up.
Yradave says relax.
07792646786
07792646786
Think all I'm missing is a washer where the plastic comes through the pivot ball and where the spring meets it as I don't have one and it has to be a specific size.
Tried making one but again, no success.
Ah well off to VW tomorrow.
Thanks a lot for the help
