Front hub set up.
What will work?
I have a late 1991 GTi floppy top and the passenger side hub is scrap.
Were all the hubs the same or did GTi's have different size hubs?
Cheers tom.
The world is a dangerous place, not because of those who do evil, but because of those who look on and do nothing - Albert Einstein
Late cabby will be slightly different mate, only different as it takes 100mm driveshafts, you can get the 90mm dremeled out to suit though. But if you can find late cabby ones, your laughing.
Cheers mate.
So what year should I be looking for? The same or could I go a bit earlier?
Mainly the clipper cabs dude.
post-84 cab or scirocco have redesigned bearing carrier, regardless of spec as even 90mm shaft cars used the mk2 gofl outer cv joint. you can tell by looking closely at them for the identification mark:
