fitting speedo cable
(In Topic #112574)
thanks
i glued the very end of the cable in to the drive
good luck
thanks
m333ksd said
is there any special way to fitting it? to make sure the gear picks up in the correct place?
thanks
No, if you're fitting it correctly then a slight bit of downward pressure should see it locate properly. There's no specific alignment. If it won't fit properly, rock the car back or forward a tad.
cheers for the help
