Fitting 7*15 ET 13 alloys
Hi
Am I right in thinking that I will need to fit spacers to these wheels in order to get them to fit correctly as the offset if incorrect, or will they fit fine as they are?
If what I have learnt this week is correct those are gonna stick out a whole lot, so no spacers. I guess they might hit the wheel arches if the tyres are large.
Need to check the centre bore. If thats wrong you risk putting the whole weight of the car on the wheel nuts.
Peter.
1980 1600 GTI, daily driver.
7 inches wide and an ET13 is going to give you headaches!
Going to catch the arches front and rear, unless the car rides standard height suspension, then you might get away with it if you dont drive it hard!
