Erk! is ?520 too much to spend on getting the car fixed!
(In Topic #86259)
Just had a report back from my local Mk1 specialists (HeriotHill, Edinburgh) following my inspection service.
Transpires I have a hole within 30cm of somewhere at the rear axle (I have no idea how these are put together, but I am told that where the hole is would be an MOT fail…)
I'm told that they need to demount the whole back end, including the fuel tank etc, and some of the interior as they need to do a bit of welding to reinforce the section. I'm also told that doing it now while there is still enough structural strength is cheaper than waiting until the MOT, by which time it might have deteriorated.
Thankfully, they've offered to fit a new fuel tank (mine is rusting from the inside) for free as part of the process.
So, including new brake shoes, the carburettor repairs (which included electrical work) and the service, that's ?240, plus ?672 to carry out the chassis repair and fit the new fuel tank (including parts, consumables and VAT) meaning a bill of ?912
Having listened to what they've said, I'm told that the rest of the car is sound and that, with regular servicing the car should go on for a good while yet.
Has anyone else had a similar issue with corrosion in this part of the car, and a similar sized bill?
In any event, I've told them to go ahead (having first spoken to the wife!) but it has eaten into my restoration budget quite badly…
AndyC
Currently Golf-less…
2004 Audi A6 Avant Final Edition - Standard
In any case they are right to say that you should sort it asap as it will only deteriorate into a bigger job and let moisture etc into other parts of the chassis area.
Good luck
1983 1100 C
1983 1100 C
<a href="VW Golf Mk1 Owners Club"> <img
http://i35.photobucket.com/albums/d189/vr6lad/forumsig_h.jpg
The quote is ?580 for the chassis repair, ?100 for the fuel tank, ?240 for the service, (including the electrical work and the carburettor overhaul aswell). So it's really just the ?580 part I'm talking about.
I'm sure the work they're doing will be of a high standard, after all they have a lot of old golf, polo, passat, fastback, beetle and campervan customers that keep coming back.
As for the value of the car, something only has value if you're selling it (and I almost did for ?350 to a mate of mine, but I'm glad I didn't owing to this problem).
It's still cheaper, more fun, and more rewarding to keep this on the road than it is to get some crappy little run of the mill runabout. And they inform me that other than that, the car is in great nick.
Cheers for all the replies.
AndyC
1980 1600 GTI, daily driver.
Care to PM me the details? I doubt they've started on the car yet, and I'd be keen to get a second opinion…
I can't really get a photo owing to the fact that I don't have the car…
Cheers,
AndyC
pop down to roseburn garages near murrayburn stadium, its owned my my mothers brother and he has done hundreds of cars over the years, mainly vws but will touch others…
they still have thier stretch beetle that was built over 15 years ago and shes still rocking.
good luck lad
Pics
I picked up the car today and the garage were kind enough to put the car up on the ramp to show me what the problem was. I took a couple of pictures and it's pretty clear from the images where the hole is.
This is the nearside mounting:
This is the offside mounting:
Hopefully this gives you an idea of what I'm looking at, and how much I need to be spending to rectify.
Thanks in advance for all your help,
AndyC
Just wondering if anyone has had a look at the pics and might be able to tell me what i need to be spending on getting this fixed?
Cheers,
AndyC
Did the previous garage explain what sort of job they would do for the price? There's a big difference in price and job between simple MOT patching and proper restoration style replacement of panels.
Your cheapest bet is to shop around for a price on simply cutting out the worst rot and patching up the areas, but you can't be sure it will be a long term fix and will probabty look ugly. Once rot has got in you ultimately got to remove all effected areas and weld in sections and paint and finish properly to ensure a good permenant fix. Pattern repair sections should still be available for this area from Hadrian panels. You will probably find the inner and outer sills in this area will also need a bit of attention if you want a proper job done.
You need to shop around for prices to get a better idea, cheapest option would be to do it yourself. All comes down to whether you want to keep the car short or long term and whether you may redo the job resto style yourself in the future and just want to keep it on the road for the meantime.
Good luck
1983 1100 C
1983 1100 C
thing is that hole on the other side aint supposed to be there and to fix that you will need to drop the whole rear beam.
Hadrian do a repair panel for this section I think
http://www.carpanels.co.uk/index_catalogues.htm
Make: VOLKSWAGEN
Model: GOLF/JETTA
Variant: 74-08/83
HCP Part Number: 91-22-373
European No: 952082-1
Description: CHASSIS RPR BY REAR AXLE L/H
I am afraid ?500 doesn't sound far off the mark.
Peter.
I've contacted the local VW restoration specialist (PFP Coachworks, just outside Edinburgh - they have a website http://www.pfpcoachworks.co.uk/).
I'll be taking it out to him for a once-over on Monday, but he reckons the ?500 mark is about right…
It's eating into my overall restoration budget, but all in all I can probably live with the expense, if it keeps the car on the road.
Cheers,
AndyC
