Drive shaft bolts & spreader plate
(In Topic #115631)
Hi, does any one the lenght and type of bolt used for the driveshafts? i seem to have lost all mine
also does anyone have 1 spare spreader plate, as i can get them machined at work, but need one as a base to work from.
Rob
Rob
M8x48 bolt, they use a splined head but you can use whatever you have to hand. spreader plates depends on the shaft, 100mm or 90mm?
100mm flange
i can get m8x50 in socket head, 10.9 grade.
will that be strong enough?
yeah should be plenty, plate is:
1J0 407 357 A - 53p+VAT
where do u get those plates from?
Rob
Rob
VW
main stealer then
