Does anyone sell recon rear axles?
(In Topic #111572)
Mine has got a wicked kink in it, the angle of the wheel is making me wonder if my car has been fitted with rear wheel steer
paulydixon.com
i assume you mean the whole cross member and trailing arms etc.
try crazy quiffs.
if you just mean the stub axle then gsf stock them i beleive.
try crazy quiffs.
try crazy quiffs.
I'm not too sure really, whatever will sort out this problem!:
I'd like discs on the back too, that's a mk2 scavange thing though yeah?
paulydixon.com
mk2 stubs and back plate i beleive.
without actually knowing whats bent you cant really make a diagnosis.
paulydixon said
try crazy quiffs.
What's the problem? The pic doesn't show it.
The wheel is at a funny angle Paul it sort of points inward, here i'll try another:
paulydixon.com
….yet it didn't seem a problem with the bbs wheels on, actually i think it's the wheels, the centre bore of them is all wrong
paulydixon.com
You'd need to disassemble and inspect things, do find the damaged part. It could be just the stub axle, or it could be the whole axle (well, trailing arm part of it).
….it's the wheels :x
paulydixon.com
You mean its buckled, or the mounting face isn't right, or something? I guess you can check if a wheel's buckled yourself merely by jacking the car up and spinning it. A tyre mounting machine is also useful, it allows the wheel to be spun quicker. Where did you buy the wheels from and was it new or secondhand?
Na it's not that, the actual big hole in the centre of the wheel is a couple of mil too small so the wheel won't sit flush on the hub. So when i tighten one nut right up, thats the side that nips in
The wheels came free with the car so god knows what they're off, i'll ebay them
paulydixon.com
