Cutting Bump stops.
(In Topic #121668)
Cutting Bump stops.
I have Koni Adjustable shocks and Eibach springs lowering the car 25mm.
Even with the konis adjusted to its softest setting the car has a massiv thud on the front suspension when hitting even the smallest bump or pothole.
Have heard and read some comments about cutting the bump stops down the same height as the car is lowered.
Is this good advice, should i check anything else first(i also have new top mounts) or advice guys??
i used fiat panda bump stops with the built in plastic bellows,there hard foam instead of rubber,most cars use them nowadays,they transformed my car instantly,othere have used them with good results,they fit well,just remove the white plastic thing they come with,and fit them,they cost £12 each from a fiat dealer :wink:
Bert
Bert
What are your top mounts like? Mine started thudding when they were on their way out.
As mentioned i have new top mounts :wink:
