Clutch
(In Topic #125826)
Clutch
I have a Golf MK1 Citi 1600cc
Can anybody tell me if a golf/montego clutch will fit? :dontknow:
should do yes, id guess it uses a 190 or 200mm clutch kit, is it a carb or injection engine
it's a carb engine
probably the 190mm clutch then. what you could do is buy a 210mm 1.8 flywheel, then 210mm clutch. then you know you wont have any nasty surprises when the box comes off. does the box have a code on it btw? this is all assuming its a big block engine with an 020 gearbox, can you get a piccy of it?
