Clutch Assembly Help!
(In Topic #133236)
I could do with a bit of advice and possibly a point in the right direction.
Im currently putting a EX 1.8 engine from a scirocco GL Auto into my mk1 golf but i am changing it from Automatic to Manual.
I have got the flywheel and need to buy the clutch kit but i need to know if the clutch kit will come with the Pressure plate assembly?
The part i mean goes on the side of the engine and it connects the clutch and flywheel to the engine block. (It is possibly held onto the engine by the 6 13mm bolts).
Im not entirely sure what the part is called and could do with some info on it or if there has already been a thread then please show me a link if possible.
Thank you for any help you can give.
James
Where do you sugest the best place for the clutch kit would be?
