Clutch Assembly Help!
(In Topic #133236)
Hi,
I could do with a bit of advice and possibly a point in the right direction.
Im currently putting a EX 1.8 engine from a scirocco GL Auto into my mk1 golf but i am changing it from Automatic to Manual.
I have got the flywheel and need to buy the clutch kit but i need to know if the clutch kit will come with the Pressure plate assembly?
The part i mean goes on the side of the engine and it connects the clutch and flywheel to the engine block. (It is possibly held onto the engine by the 6 13mm bolts).
Im not entirely sure what the part is called and could do with some info on it or if there has already been a thread then please show me a link if possible.
Thank you for any help you can give.
James
James
Thank you. This is the first one iv done.
Where do you sugest the best place for the clutch kit would be?
ebay is where i get mine from, sachs is the kit i recommend
