clutch advice needed!
(In Topic #73538)
when the engine is running and clutch is pushed down i try to select a gear and it stalls the engine.
when the engine is not running it will select the gears.
is this gunna be a gearbox back out job?? any advice would be much appreaciated.
bearing has come off the fork,clutch pressure plate is the wrong way round, or the cutch cable is to slack and is not pulling the clutch fork enough.
