Clipper MK1 Gear Box Sticky and Speedo not working
(In Topic #95749)
My golf has no speedo working along with the gear box having trouble selecting second and popping out in fith some times. Please can you someone offer some advice??
Many thanks
Pr_76
The only real remedy is replacing with a reconditioned gearbox, so it depends how much of an issue it is day-to-day whether you decide to do this or not.
Apparently people have seen temporary improvements by changing the gearbox oil and/or adding some kind of additive to the oil.
The speedo not working sounds like a speedo cable issue, as detailed above.
Welcome to the club…
How much should i be looking to pay for a reconditioned gearbox??
pr_76 said
Gents thanks for the response.
Probably around ?350-450 or more. Or you can take your chance with a secondhand box, these typically go for ?50-100. A garage would normally charge ?80-200 to swap a box (varies a lot between garages). If you're swapping the box, it would make sense to look at the clutch and replace this if worn, so add around ?50 or more for this too.
Will go for a recondition gearbox not a second hand one. If anyone knows or has experaince of supplier and fitter please let me know.
Will be talking to this company tommorrow.
Hardy Engineering - Gearbox Repairers in London & Surrey
