Cant get gears-help
(In Topic #126966)
Cant get gears-help
if so then yeah most likely the clutch.
Jon.
best bet to whip the box off and remove the clutch plates and clean them up or replace them up to you i would replace if was me check the bearing as well while your there
if you do have any problems give me a pm
thanks
Aaron
AR Motor Repairs
General Servicing And Repairs
www.armotorrepairs.co.uk
Tel: 07956369984
Tel: 07956369984
Extreme care must be taken and I wouldn't advise unless you have PLENTY of space are 100% CONFIDENT you can do it. It may also break something in the drive traing.
The trick is to start engine neutral and run until it's up to working temperature.
Making sure you have lots of space in front of car, turn off engine. Engage 2nd(?) gear and then attempt to start engine with your foot on the clutch pedal. Because the engine is warm and just run it should start instantly and lurch forward and free off the seized clutch with a bang. Be prepare to turn off engine incase it sets off going forward.
