camber bolts
(In Topic #125917)
camber bolts
hello, can somone tell me about camber bolts as i need some, thankyou
you have 2 types from vw, you have the mk1 type cam bolt which is nla, or the mk2/3 type which is basically just a bolt with a thinner shank. the mk1 item is easier as you can change the camber by spinning the head of the bolt with a spanner, with the mk2/3 you have to shove the hub about manually to set it
out of interest, where actuall are the camber bolts
thanks
nick
thanks
nick
where the suspention strut bolts to the wheel bearing housing assembly
Hello,
can someone please help me, don't use this website much,
so my apologies , due to being ill for 3 years
I have a big problem, with my MK1 golf clipper 1990, is fitted with a WEBER 32/34DMT Carb,
it won't hold its power and dies when demanding more power, I have cleaned out the petrol tank changed the flue pump , this happened before and I replace the carb, surely there must be something killing the carb and how can I repair a WEBER 32/34DMTL, as I have two in my shed for this same problem, what about the mapping unit, how can i fault find this problem, as the car is just sitting outside, with winter here i need to get it fixed,I am not a Mechanic, but will have a go
