Camber bolts
(In Topic #73272)
Camber bolts
Hello all,
I am wanting to replace the two bolts which go through the bottom of the suspension strut which bolts to the hub.
Does anyone know the VW part number for the Camber bolt and spacers.
Regards
Scott
Regards
Scott
Top adjuster bolt 171 407 265
Cam washer 171 407 267
Spring Washer 171 407 239 A
Nut N 011 135 1
Bottom bolt 133 513 471
2 x Spring Washer 171 407 239 A
Nut N 011 135
This is from the parts list but i thought the top and bottom nuts were different sizes?
Nut N 011 135 1
Nut N 011 135
Hi
You would be better off buying the fitting kit from VW its 171498101A and has all the bolts washers and nuts you need for ?12.18 per side
1996 Gti Anniversary 8v Mystic Blue
1995 Gti 16v Fjord blue
camber bolts
Thanks guys,
I think I'll go for the kit, presumably it at has top and bottom bolts washer and all.
Thanks again
Scott
Thanks again
Scott
