bump stops
(In Topic #110490)
bump stops
i have a mk1 cabriolet,just had Eibach pro kit springs fitted all round and Boge gas assisted shocks,the problem is the car is sitting on the bump stops and crashing out while driving,the VW specialist that has been working with me on the car has done vanishing act and i dont no whether i need to cut the bump stops down and if i do by how much.if any1 can help i would be very very gratfull.
ive got a eibach pro kit on my TD,the rears are fine,the front is sitting on the stops,it drives poor,very bouncy,
I have read the technical bit and eibach state to use standard shockers and bump stops on there site,so i did,i used all new parts,top mounts,bump stops,complete new legs etc,i wasnt happy,called eibach,there useless to be honest,waste of time,they sent me another set of springs,still the same,im still waiting for a phone call,that was 2 weeks ago,
I went out and replaced the brand new oil filled shocks with boge gas turbo inserts,the boge inserts travel 30mm more than the origional oil shocks,so less chance of bottoming out,i put the legs on the car,still on the stops,
I ended up using fiat foam bump stops with the built in corrugated dust covers,there smaller than the vw ones by 30mm,and if they do bottom out its a smooth stop as there softer than rubber,
put the legs back on the car,now sits on the springs and drives ace,and theres still travel before it hits the stops,
I can get you the part number for the fiat stops,there off the new panda,perfect fit,just take the white plastic cap off to fit them,?12 each
Bert
i rang venom motorsport to ask them about the problem,they insisted that the eibach springs should fit on standard shocks,i told them that i had uprated the shocks to the turbo gas ones and he stated that i should cut the bump stops in half…..not to keen on that idea,some people have said to cut the bump stops down in relation to how much you drop the car i.e 30/35 mm, would it be easier just to fit the fiat ones do you reckon or just cut them down.its doin my head in cus the poor golf is sat on the drive for nearly 6 weeks and i just had new roof fitted and cant show it off lol
Bert
cheers chris
Only other thing I can think of is that the springs I have got are maybe lower than -30mm. If it is the bumpstops causing this do you think the fiat ones will help? was going to just put the standard springs back on till I read your post. Got to take it all apart again anyway cause the motorfactors gave me the wrong topmounts!!
Any advice you could give me would be great.
P.S - I'm sure you know to get your tracking and camber adjusted afterwards, but if you drive it temporarily without adjustment, imperfections (like repair joins) in the road can bang a lot more than normal which won't help matters. They did in mine anyway.
