Bump stop length??
(In Topic #72807)
Bump stop length??
Does anybody know what the length is of standard mk1 bump stops are? Are the fromt and the rear lengths the same?
Thanks for looking
regards
Scott
I ordered some bump stops from German and swedish and cut them down by 20mm as the lowering kit said (GMAX VW07 kit) drop quoted from manufacturer as 20~25mm from GTI ride height (current ride height should be 320mm).
But…….the front is a full finger width higher than the back!! I cut the original rear bump stops down by 20mm and used them instead of the ones from German and swedish as they looked more suited to a tractor.
However I had to use the fron ones from German and swedish as I had no others, I cut them down by 20mm. But it is possible that they are still to big, could this be the only reason it looks like I am driving round with my handbrake on?
So does anyone out there know the length of a mk1 front bump stop?
The front bump stop r 84mm and the rear 71mm
Cheers Wellsy
1983 MK1 Golf GTI (Campaign?)
1983 MK1 Golf GTI (Gone to VW Heaven)
1990 MK2 Golf GTI G60 Edition One
Good luck,
Mark
