bulkhead split !!!
(In Topic #116791)
bulkhead split !!!
my bulkhead has split and bloke at the garage said i needed to buy a plate to fix it. does any1 no what he means or were i can buy 1 ?? clutch still works at the moment but would really like to fix before it comes through completly.
thanks
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
how do these fit?>
are they welde in etc?>
thanks
Not the prettiest fix but it did work surprisingly well.
Jon.
it has a sticky pad on one side and is easy to fit!
Works a treat!!!!
worth doing properly me thinks.
Jon.
On RHD cars its a long twisted route that puts pressure on the un-reinforced bulkhead that eventually fractures the metal.
When the cable is setup up right it holds the reapir plate in place so it only needs the sticky pad to aid fitting. In the past I've used a couple of self tappers as a belt and braces approach.
not a pretty fix though is it? I'd prefer to seem weld it if possible.
Suppose it depends on the owner in that case!!!
Jon.
Ended up CNC machining a hench slab of ally with all the necessary holes in it and just lobbing it over everything. Did the job : :mrgreen:
