Brakes help
(In Topic #159923)
Please help
Martyn
Last edit: by smudger
Set it about 1/3 way and give it a test run, if it locks at the rear, back it off, if it locks at the front, you could do a little more rear braking. But its a very rough way of setting it, unfortunately.
basically when set like this you have set it to minimum possible rear brake assist under normal conditions (which is what you want!) then any weight in the back will start adding assistance
