Big Automatic Problem
(In Topic #144741)
I own a 1.6GL 1986 Automatic, it's a Cabriolet. Basically I have been driving in 2nd gear for about a month now.
I can manually use gears 1 and 2 and even Reverse, without a problem. However, Drive will not work.
If I go from second and then into Drive, it puts me back into 1st. :?
Any help will be greatly appreciated.
When it first stopped working, I checked my transmission fluid, was hardly anything and dark. Filled up. Dipstick says it has enough fluid but the fluid is dark brown which isn't good.
When I get a good day free with good weather in the next few days I will follow the instructions of the sticky thread about changing the fluid and filters etc. Whether that will sort the problem I have no idea… any ideas or has anyone encountered a similar problem?
1986 Golf Cabriolet Auto GL, 1.6.
drain fluid, replace filter and oil with fresh stuff and see where that gets you. you might need a couple oil changes if its really grotty inside the box
