Audi calipers and carriers where????
(In Topic #76916)
Audi 80 quattro (83 to 85)
Audi 90 5-cylinder (85 to 87)
Audi Coupe 5-cylinder (85 to 88)
Part Numbers:-
Caliper carriers - 853 615 125 (x2)
i have been looking on ebay for months now and i am getting a bit fed up.
if any one know a breaker or anyone one who has some please could you let me know???
also if anyone knows of other 256mm conversions that will be easier to find parts for.
Thanks for any help
Rebuilding Again…
Rebuilding Again…
Rebuilding Again…
I had the same trouble when considering this brake upgrade.In the end got so fed up i bought big brake conversion from TSR.
But i've just seen a ad in the back of golf mag
AUDI 90 QUATTRO FRONT CALIPERS ALLOWS YOU TO FIT 16V
BRAKES.NEW SEALS AND BLEED NIPPLES
?75 THE PAIR.
0191 2372436/07951 847343.
hope this helps?
jess
Damn so close!!!
Rebuilding Again…
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4598430222&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
As for calipers from other cars - I'm looking into something interesting but it might not work so keeping it under my hat for now :mrgreen: Personally I don't like the idea of using caliper spacers, but enough people use them. Some of the people on the Caddy forum have used G60 calipers on adapter brackets.
Cheers,
Mark
Theres a coupe and 80 quattro.Doesnt say what year,but i think one of them has a number to ring.
Good luck :dontknow:
Rebuilding Again…
Rebuilding Again…
Now the Volvo is a big arse caliper so not sure on wheel clearance :dontknow:
Rover do a 262mm disc I think but a little bigger would be better.
www.vwcaddy.com
Cheers,
Mark
i think im just gonna do the master cylinder and servo for now and keep a look out for the bits i need.
If some one could source technical drawings for the carriers i could make some, as i am studying auto engineering at uni.
What are the chances of being able to make the carriers from scratch myself??
Just a few ideas.
Rebuilding Again…
what are the posibilities of getting bolts made up to do the conversion?
or even some sort of sleeve to fit the bolt?
Rebuilding Again…
The other thing I was thinking of was Astra 16V / Calibra calipers as they use a 256mm disk, so theoretically would suit the 256mm Golf 16V disk. I'd heard of people using Volvo calipers on Vauxhalls, so I thought the same 'turned down bolt' method may work (?)
All of the above completely untested and none of it may work !!! A lot depends on how the caliper sits on the stub axle, and how inset or otherwise the chosen disk fits.
Just ideas - might be talking a load of sh*te !!!
Cheers,
Mark
my mate is in to vaux halls so i might ask him if he can lend me some of his older bit to play with and see if the astra 16v part could be fit.
lets see.
Rebuilding Again…
TSR BRAKES
