Attaching Handbrake Cable at Hand Lever?
(In Topic #121262)
If the ratchet has spun and its not "biting" you need to pull the lever right up and try to spin the ratcchet mech 180 degrees, i achieved this with a thin screwdriver. Its pretty simple. Once its spun back around then hold it in place until you lower the handbrake and the ratchet should be working again. Then re attatch the cables, i hope this helps, if its too confusing maybe someone else can advise or you can ask me to explain better? Thanks.
Thanks for the Information!
