Accelerator hits the DECK
(In Topic #125106)
Hi
So my car is running like a dream at the moment, i'm on to get about 350 miles from a tank (mental) after i did a few bits.
However just now I started it, and the accelerator hit the deck and the revs didn't change. great I thought, i've snapped the cable. But a check by the pedal revealed the rubber grommet has come unstuck and unclipped the cable from the pedal. I hooked the cable back in but it's not that stable.
What is the name of this small rubber part? I can't find it, help would be appreciated. it's small and orange.
Cheers!
Cheers!
low, and slow.
as above normally the small rubber bush has perished, the post above will give you the part nos and some advice regarding the MK2 bush vs the mk1 bush at the end. I used some tape just to hold the bush in while new part arrived.
1988 1.8 carb Golf Clipper
