928 wheels
(In Topic #158733)
Hi i'm looking at getting a set of Porsche 928 wheels n just wanted to know how easy they are to fit.
Fronts are : 16 inch
7 inch wide
et 53 original
20mm spacers
new et 33
Rears are : 16 inch
8 inch wide
et 52 orgigal
25mm spacer
new et 27
Iv been on wheel calculation sites and they seem as they will fit but it looks a squeeze so if anyone out there has fitted similar
would like your feedback
Thanks Will
7 inch wide
et 53 original
20mm spacers
new et 33
Rears are : 16 inch
8 inch wide
et 52 orgigal
25mm spacer
new et 27
Thanks Will
I haven't fitted any myself but the actual size shouldn't be a problem. You may need to 'massage' the arches slightly though. Depends on how low you are and how the front camber is set up.
I take it you've also taken into account the size of the PCD adaptors within your calculations?
E
E
