4 t0 5 speed converison
(In Topic #72892)
And by 4spd, do you mean early 1600 gti 4spd or 1300 Driver 4spd?
My Build Thread
Life Member
4+E
Before you even start though you want to check out the codes on the boxes and compare them to these charts:
http://www.nwlink.com/~vdb/vw/Transmission/speed-ratio.html
VW 020 5-Speed Transaxle Ratio Chart
This will help you work out if the boxes have different ratios or not.
You also need to ask yourself why you want to change. If it is shorter ratios you are after, check out the links above to see which are the short ratio boxes.
Hope they help - they sure helped me!
AL
My Build Thread
from my 1976 1.6 ls 4 speed
to
a 4+e or 5 speed mk1 gti box
If you want a box for motorway cruising, you want an 1800 Gti 5spd box.
Check the codes of any boxes you find against those links I posted, just to be sure!
My Build Thread
