22mm master cylinder help please
(In Topic #144608)
just put a 22mm master cylinder on my project can any body please tell me what outlets fed what,it is a 4 outlet m/c
hi scotty i think the front two ports are for one front and one rear say n/s/front and o/s/rear then the back two ports would be o/s/front and n/s/rear i think this is correct :wink:
have you checked the guide at the side ? , its quite good , brake upgrade i think its titled
The Mk1 Golf Owners Club
yep as mk12at says the front 2 ports are a single circuit, the back 2 are the other circuit. you should fit opposite corners to each circuit. if you also need to fit brake pressure switches put 1 in each circuit and use a mk2 golf T piece to split 1 port into 2 for the brake lines
thanks fellas 8)
