20vt swap wheels won't turn
I have Put a agu 1.8t in my mk1 with mk1cabrio drive shafts for conversion but when I pull the hub nuts up the front wheels lock solid is there suppose to be spacers or something between the hubs and the shafts it's defiantly not the brakes as they still have a little bit of movement in them if u have any ideas what it could be it would be much appreciated cheers
bet you got 90mm hubs and 100mm driveshafts,they dont mix  :|
Bert
Thats not a rod knockin,its a diesel stupid! floppy top and 1 tin top
Yeah what Bert said.
What part of the hub does the 90mm relate to cos I will measure to check sound about right that would be just my luck lol bloody thing
are your hubs stock
(as in original) or did you match the hubs to the driveshafts when you got them?
Hubs are stock mk1 gti 83 drive shafts are mk1 cabriole 100mm where they bolt to the gearbox
You need later hubs from a cab or rocco dude.
Or you can have the lip on your current driveshaft turned down to stop it binding on the hub.
I just got later hubs tho as its easier.
