1st gear prob's ????
(In Topic #76831)
Easy job and will be worth the couple of hours work. You can also change the g-box oil to synthetic oil which can sometimes take away the 'crunch!'
Conversely both the GTI and Caddy (180K and 120K respectively) are fine. Both have 75/90 semi synthetic in and new bushing.
I?m sure that replacing the bushing will improve matters greatly.
hum
I've bought off ebay as well a plate you can stick on the bulkhead to save welding, and it was only a fiver. I think mine is on its way out as well. After welding i had my clutch adjusted every now and again and it would solve the problem.
Good luck and hooray for cheap fixes!!! :mrgreen: :mrgreen: :mrgreen:
