19mm master cylinder connections & pressure switches?
(In Topic #137365)
I understand it will b a combination of 2 brake light pressure switches and the front and rear brakes, but needed some idea as the order and if T pieces would be needed for the brakes (and if they needed to be installed diagonally. Hope this makes sense.
thanks.
ps. yes i know the servo is missing - call it an experiment…..
1980 Series 1 GTI (gone now .. what a mistake selling her!)
1979 Series 1 LD - the Mandarin Dragon … gone as well. oh dear.
you should have opposite corners on each circuit so if one fails you still have 2 working brakes on opposite corners of car.
so front 2 you could have front left and rear right, back front right and rear left. or the other way round, it makes no odds just as long as opposite corners are on each circuit.
if its an early one you also need pressure switches, can fint those with a t piece. or switch to later brake pedal mounted switch
