How to join a region and get access to your regional section of the Forum
(In Topic #182196)
Step-by-step with pics
You may or may not know, but there is a dedicated section of the forum for almost every region of the UK (if yours isnt there and you would like to front it get in touch).
To access a dedicated regional section of the forum you need to be joined to that region.
There are 2 ways to join a region;
(1)Be added by the regional host
(2)Apply to join the region
To join a region, go to the top menu bar and hover over "Members/Regions" and select Regions from the drop down menu that appears. From the page that loads go to the "Join a region" field and from the drop down menu select the region you wish to join. You can join as many regions as you like (the dedicated section on the forum only shows once you've joined)
If you would like to find out who your Regional Host is then click here;
Mk1 Golf Owners Club Regional Hosts - The Mk1 Golf Owners Club
I hope that helps!!
Scott
I hope that helps!!
Scott
Oooooh thanks mate, I'll check this out later, at longleat at the mo
I know this is an old post but can't find a more relevant one. Anyone know to do it now the website has been updated?
Or if someone could link me to the correct place or something that would be awesome. It probably obvious but I'm new to this.
I am located in the Shropshire area but can travel to Cheshire, North Wales or more sort of west Midlands and Staffordshire
thanks in advance
Chris
thanks in advance
Chris
1992 Clipper Cab converted to single headlights
Powered by 1.9 TSR Donnington gasflowed engine
4-1 manifold
Stainless steel custom exhaust system.
Now rocking a fresh new mohair roof and respray 🤙🏼
4-1 manifold
thanks in advance
Chris
Sorry Chris I can't find it either and I've been looking for ten minutes.
But I know some great guys and girls that will!
Web Team
As far as I can see if you go into your profile , select edit and scroll down to Additional usergroup membership, you can pull up the list of groups you can join by clicking the usergroup directory, find the group(s) you want to join and click on them, you can apply to join the group there.
Any bother drop us a message with what group you want to be in and we can add you to it manually.
HTH
lhasadreams
can we have the dropdown "Pick a region" menu on the new upgrade please?
HTH
Website Manager
HTH
lhasadreams can we have the dropdown "Pick a region" menu on the new upgrade please?
Hi Glen,
This has now been done.
There is a menu option under Members/Regions on the main menu.
When you get a min can you fix the guide on this post please.
Web Team
Has anyone had a really heavy clutch pedal
Created a new post for you Brian in the correct forum section.
Your Moderator Team.
Last edit: by golfcabrio
Please ignore!
