Slippy8v's Syncro now with MOT
(In Topic #156757)
1992 VW T25 (T3) 14 Inch Syncro 4x4 panel van 1.6 Turbo Diesel
Front and rear diff locks.
Yes I know its only a van but!!!!!!!!!!!!!!!!!!!!
Fellow club member in the local Bug and van club had it for his business as there was going to be a requirement a few years ago for trailers to be towed by a 4x4.
Ex army then bought by club member used for a few years then taken off road in 2002.
Dry stored since then. Starts runs and stops also front and rear diff locks operational.
Current plans to replace the following.
Flexi hoses all round and any brake pipes that need replaced.
Rear brake drums
Rear brake shoes
Rear spring kit
Rear brake cylinders.
Front brake discs
Front brake shoes
Front brake callipers
Outer CV boots
Oil and coolant change all filters and cam belt.
Body work wise seems very solid but rear wheel arches to be replaced and the passengers step, all panels from VW heritage. Respray on both sides and roof. Front and rear paint fine.
Interior wise drop the bulk head by half and insulate and repanel and cover interior, fit rock and roll bed, kitchen pod and folding buddy seat, leisure battery and charger.
Retrim front seats and door cards.
Will use as day / surf van.
Extras way down the line
Rear spare wheel carrier
Side rock sliders
Change alloys to VW originals.
Roof rack
Decoupler for 4x4 system
May be 1.9 TD golf engine (gearbox upgrade needed)
My New Year's resolutions are: 1. Stop making lists. B. Be more consistent. 7. Learn to count.
3 8x4 sheets of 4mm ply did both side door panels and the 3 big side panels just need to do the tail gate panel.
Slowly slowly with the jigsaw so no wavy lines. Have not decided what colour of finish do do the panels but the all the rear will be trimmed out.
So whats left? New fuel filter after draining the old diesel out she had been running on red (not very good) had her ticking over to burn some of it out and rad fan coming on ok.
Called with body guy and he's got a slot in the next 2 weeks.
So looks like its starting to fall in place still a few hose issues to sort but looking good.
leak spotted on injector need to replace blanking plug. Air filter canister removed and filter checked ok.
started and left ticking over,small water drip on plastic pipe to rubber hose at rear will fit new hose clip. Old (red )diesel nearly all run out ,gauge now in red so time for some nice fresh juice and injector cleaner. Tyres need changed as cracked with sitting so looking some new
225 70r 15 c .
