Jessie the tdi mk1 jetta (haldex conversion begining...) 12/09/17 update!
(In Topic #167199)
once we got it home the transplant could begin, the engine came out on Saturday, the engine bay was steam cleaned today and I must say has come up very clean indeed! (Pic was taken before being washed!!!)
Conversion parts at the ready, mounts from the just caddy and a hydro clutch conversion column from just caddys too.
the donor vehicle, a bora pd130 highline, bought from a friend that got T-boned at a junction,
oh and my 22mm master cylinder and 9 inch servo too,
plans for this week are:
Drill out and move engine mount to big block setup
swap column and brake linkage setup for 9inch setup
make up new brake pipes
mount clutch fluid pot and run line inside car to gearbox area
send off bora wiring loom and ecu to vagtronics for immobiliser decode and loom slim down!
thwt should keep me busy for a bit! Waiting formy clutch to arrive so I can mate the engine and gearbox together and I can get the Cambelt kit and waterpump on and conversion mounts fitted,
Last edit: by jamiegolf
Mk1 Jetta (Jessie) build thread here
View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
T25 westfalia camper, 2.2 Subaru powered
vw touran 1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck……. www.jsgarageaberystwyth.co.uk
Design Manager
2018 Up! GTi 1.0 TSI
2015 Mk7 Golf R 2.0 TSI 4motion DSG
2011 Caddy Maxi Kombi 1.6 TDi
1982 Mk1 Golf GTi 3 Door 1.8t - Build Thread
swapped the steering column for the hydro clutch version
old one removed
New one installed
managed to get the small block mount removed, only to find that the one I bought a few weeks ago turns out to be a gearbox mount not an engine mount!! Might just spin the old one over and use that,
going to get the engine bay stripped and cleaned again, get the engine mounted in place, and tack the engine mount in, then remove the engine again and weld fully, then going to stone chip the lower half of the bay and then paint under the bonnet to freshen it up a bit,
got the Water pump and Cambelt kit fitted this afternoon too, also got the covers cut and conversion mount trial fitted, need to get some shorter Allan key bolts to fit the mount properly.
Clutch kit and flywheel bolts arrived today,
heres a picture of the part number for future reference ( golf mk3 2.8 vr6 clutch kit)
Clutch fitted, just waiting for the gearbox to dry and I will mate the two together forever!
got a little bored while I was waiting for paint to dry and did a bit of colouring in!
started stripping the brake servo and brake bar out tonight, disconnected the brake lines and got the master off, ordered my clutch flexi hose and fittings today too, 6mm pipe for the clutch pipe, with a pressure switch along the way somewhere (cruise control cutoff switch) probably hide it under the dash somewhere, also got to fit 2 T pieces in the brake lines one for the lights and the other for the cruise control cut off.
next plan of action is
strip engine bay of all wiring and brake setup
trial fit engine and weld in Cambelt chassis mount,
offer up clutch flexi and make bracket for chassis leg
remove everything from within the bay and degrease
Stone-chip lower half of engine bay
paint entire bay before refit
Had a go at mine the other week as I am going hydro and 2 hours later they're still in place. Any tips?
Design Manager
smudger said
COming along nicely now. How did you find the anti theft bolts when removing the steering column.
Dremel or Angle grinder if you have a steady hand mate, I did mine, took a while but if your careful its not too hard…
I have also been thinking about a PD… so will deffo be keeping an eye on this one!
Good luck mate, love mk1 jets, look forward to seeing it finished!
I used a grinder with a 1mm cutting disk to cut a slot in the bolts and then turned them with a screwdriver with a spanner attached to it! Was quite easy I must admit!
No point hanging around is there! Had the engine and mounts ready for the mk1 I had, since sold that and bought Jessie so everything was there and almost ready to fit, wiring loom is being sent tomorrow to vagtronics to be converted and the immobiliser deleted, should make the wiring an easy job instead of a ball ache!!Ashlol said
Fair play Jamie youve got stuck in straight away! Best way really, lost interest in mine since i got that valver off you, but been thinkin i need to get crackin before i lose the garage space!![]()
Good luck mate, love mk1 jets, look forward to seeing it finished!![]()
My new chassis mount has arrived, that has been cut from the chassis leg it came attached too, need to grind the spot welds back abit then make sure that fits, might get the engine trail fitted this weekend, mock up the clutch hose and make the bracket for that, remove the old brake pipes and basically get it ready for painting. Oh oh I've also got myself a set of wheels coming! There going to be refurbished straight away with a little twist! Pics to follow tomorrow
the 4 way brake pipe tees make plumbing much easier, one switch for brake lights and one for cruise control cut off,
Then we got onto this slight issue with lining up the bolts to begin with but got it in eventually and got it tack welded, we then removed it and fully welded it all round
oh yeah engine went in for a trail fit too!
More soon………….
where are you getting your clutch line parts from and what bits are needed?
Old dubs never die, they just get lower
Spent quite a bit of time yesterday working out brake pipe and clutch pipe routing, don't want it to looked cluttered with pipes but want it functional, I was thinking about a wire tuck while I was stripping it all out but decided against it, I'm not stripping the bay to bare just for looks, it needs to be functional and factory looking.
Ye it's guna be an epic street sleeper when finished, almost standard from the outside apart from the wheels and the coilovers, should be on the road late jan or early feb, run it for a bit and give it a shakedown, then head to long life in Oswestry for a custom stainless exhaust, nothing loud, watch this space!
