Wilkos cabby
(In Topic #200949)
TLC project
Mainly the electric roof won't go down but seems switch is broken but can't here relay clicking (unless doing it wrong) but gonna try manually.
Well few pics will keep updating this
Last edit: by wilko13
Wilkos cabby
Spark plugs
Ht leads
Fuel filter
Passanger track rod end
Cambelt kit
If you want to move the roof before fixing it, you can open the tap valve on the pump, in the left side of the boot. Then just pull it back by hand
It's not looking too bad now the dirt is going
Wilkos cabby
Will you be adding these to your shopping list?
Coolant flush and replace coolant
New oil filter and oil.
Dissy cap and rotor arm
A new alternator belt is also a good idea.
Look inside the fuel tank for rust/grit and check the filler neck as if the car's been sat for a long time with little petrol in the fuel tank it will go rusty and if you can stop/clean it before it goes into the fuel system you will save your self a lot of time and money with running problems.
Wilkos cabby
Wilkos cabby
Expansion tank
Ht leads
4 spark plugs
Alternator belt
Timing belt
Air filter
Fuel filter
Track rod end
2x wheel bolts
Seems well priced to me
Hoping to get most of it fitted this weekend
Don't forget a new timing belt tensioner is a good idea.
http://www.carparts4less.co.uk/cp4l/c/Volkswagen_Golf_1.8_1988/p/car-parts/car-service-parts/major-service/tensioners-idlers-dampers/?328440040&1&5e288759daf4aee959ac7003fc1c82d68f9b22ef9ee6175b6ffbd04386f5fe4f3eb4b313a9b5a0cc&000091
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_1.8_1988/p/car-parts/car-service-parts/major-service/tensioners-idlers-dampers/?328440040&1&bfefb62f2a2452e8e998f2eb9bc607b890a8f928&000091
Dissy cap and rotor arm also missing from list.
I would also change the brake fluid and fit new rear brake wheel cyinders (change them before changing fluid) and may fit new discs and pads up front and have a very good look at the rear shoes and drums. The brakes are a very important bit of any car so not worth taking a risk with them.
Wilkos cabby
I know someone who just had their tensioner bolt snap on their VW Sharan, mashing the whole head as a result! It looked like the tensioner had been replaced on the last belt change but not the bolt as it looked very old and rusty!
Hairyarse said
I would always replace the tensioner too on a car that you don't know.
Can say I've never changed my tensioner bolt/stud and it's never looked rusty in the 21 years I've owned the car.
Perhaps the few oil leaks over the years has stopped it going rusty?
Wilkos cabby
Wilkos cabby
Wilkos cabby
Wilkos cabby
Wilko13 said
Euro car parts. Gonna get money back and give vw heritage a ring
To be honest from my experience, Euro have always been bad! I've never got the right part from them first time, irrespective of what info I've given them. I stopped using them a long time ago!
As you say, give VWH a try and don't forget Mark at Classic-VW
I've never had a problem ordering parts online and always get the bits I need if you are not sure which parts to order ask on here and we can help, your car and engine is same as mine.
The Mk2 Golf GTi did have the same engine (DX) at the start of its run and changed to the PB engine later in production but that is still a simular engine it just have a different fuel injection system, timing belts, alternator belts, oil filter, spark plugs, HT leads will all be the same, air filter is different.
Sister company and even cheaper.
So which parts are wrong and what do you need and I will post up a link to the right bits.
Last edit: by mark1gls
Wilkos cabby
