Smudger's 20vt Project A.K.A Patsy. (Update 07/06/2015 Got the love back)
Smudger's 20vt Winter 2012 Project (UPDATE 23/12/12)
smudger1980 said
Dubbuds said
Nice updates there what will your gauges be reading?
I have a Depo 52mm water temp gauge already but still undecided on the other 2. Am considering oil temp/pressure and/or a boost gauge. Any suggestions gratefully received
Boooost! VDO do a nice original looking one that I've got my eye on:
http://www.arz-tuning.de/shop/product_info.php/info/p11584_Illuminated-VDO-Boost-Gauge--1-Bar-to--1-5-Bar.html/MSsid/cktmkancukdonqempmhv9idbe2
or boost/AFR combined gauge?
I'm having a bit of a dilemma about which of my gauges (oil temp, pressure or voltage) to drop in favour of a boost gauge!
Might go for oil pressure and boost from Depo to have a matching set. in there.
Design Manager
smudger1980 said
I'm having this dilemma too guys. Pete AFR is ballache for me now as I would have to take off the downpipe and have another bung welded in to take the attachment.
I have Newsouth Indigo Boost, Oil Pressure and Voltage gauges in my centre console. I did contemplate AFR but decided against it, I wish I had now though as I'm still not 100% sure my Lambda is working. They all match my Lupo clocks which are backlit with the same blue. My dash is currently on my 'sort' list too.
2018 Up! GTi 1.0 TSI
2015 Mk7 Golf R 2.0 TSI 4motion DSG
2011 Caddy Maxi Kombi 1.6 TDi
1982 Mk1 Golf GTi 3 Door 1.8t - Build Thread
Design Manager
http://racediagnostics.com/cms/index.php?page=liquidgolf-options
This is the route I'm going, saves messing with my exhaust and is effectively like having VCDS plugged into the ECU all the time, will graph and map your AFR as well as a lot of other values for not much more than the cost of a decent gauge. Plus it looks pimp! Would require some thoughtful mounting though, I am having a custom dash fascia so it's not a problem for me. I am confirming if it supports AFR or not, it says missing but with a ? after it.
Joe90k said
Before you do what Pete's saying Smudge, have a look at this:
I'm liking the idea of this mate if it does AFR as well. Let me know how your enquiries go. Looks like it's just plug and play.
Design Manager
Joe90k said
Does fault codes too which is a plus
I feel a custom holder fabrication job coming on
golf_coupe said
does look slightly more subtle than an I pad in the dash lol
I'm looking into modifying the original boost gauge holder by the gear stick in some way to accept something like this so if suitable it would be great. My 3 gauges will be above where the ashtray was as pictured on the previous page.
ALL of it :-)
The last time I had AFR and VCDS I went to the docs and got some cream ;-)
AFR should never fluctuate to far unless you have a bad map.
