Pee's cabby
(In Topic #187678)
I'm part of Unphased in the north west so done a few shows in my previous car but all the shows made me do is want a mk1.
Now I also need a bit of help if anyone can point me in the right direction.
I need a manifold and weber carb for a 1.8 asap it's sat there and I can't drive it!! Cheaper the better as long as it works.
Thanks for looking Paul
B reg cab
Also get a little 'Bumpy' as your looking for a Carb.
Rebuilt kit is fairly pricey as are the adapters for manifold and air box so try and get a complete running set up otherwise you might aswell just but a new kit.
sounds right in theory but im not good with engines
It's shot down as some people have problems with carb icing in winter and also in summer the carb is sucking hot air from the rear of the engine bay rather than cold form the front.
Anyhow mine didn't ice in the limited winter running mine had. I think some people fail to install the block heater off the old pooburg. As far as the hot air, well mine isn't a race car but still pulls fine in the high 20's heat.
K&N does look nice and gives a great roar. It's pricey though new. I picked mine up used bolted to a weber dmtl. Same mounting. Sold the dmtl afterwards for what I paid so freebie!
so on my parts list I need
inlet manifold
weber
gaskets
bolts
pooberg block heater
k&n filter and a mount
this is gonna be a joy to do haha thanks for the info jay
Pee said
Don't worry il be a paid member soon. Need to get her running and see how much that costs me. When is the one in Leeds?
Hi its the 15th/17th of August tickets are £39. from Friday to Sunday.and it is a great show lots to see and do.If you were to go and are camping get it booked soon as this one gets bigger each year.
B reg cab
u get
1.8t aum engine
5 speed box
ecu and loom
engine mounts
alternator
pas pump
inlet and exhaust manifolds
what else will I need?
also what gearbox does it come with?
might be best keeping my old one in
