My Mk1 Golf GX Project
(In Topic #184761)
bought the car last January from a guy in Bolton, Manchester. I had to travel 160 miles each way after one phone conversation and one picture on the advert on Gumtree. He told me that it would run and idle, however it had some stuff in the tank so would cut out every now and again but should be fine if left off for a couple of minutes. Armed with this information, my mum and a mate set off on the journey to pick her up!
(This was the only picture that I had before I set off)
So, A few hours later and £900 lighter in the bank I had myself a good looking, fairly solid Mk1 Golf. I got told by the guy that it had lived in the same estate it's whole life and he had seen it everyday as he walked back and forth to school. It was garaged when it wasn't being used and was owned by an elderly gentleman. When he passed away, he left it to his grandson who then kept it garaged for a few years, not knowing what to do with it and eventually sold it to the guy who I bought it from. The way home was a bit of an experience. It broke down a few miles from the guys house, with the fueling problem. I was stuck on the motorway for a few hours until the AA could rescue me.
I managed to take it to a couple of meets, Including the Mk1 regional meet:
By Big Bang 2013 I got a brand new Webasto open air imported and fitted by a company in Bedford.
And managed to get some Schmidt TH line split rim wheels for her
Got the wing off, waiting for a new one to go on
This is as far as I've got, Ill post updates as they come
Last edit: by TravisPrice2
matt
1.8T CABBY
1.8T CABBY
I have the same car with the same rust in the tank still to sort
Keep the updates coming
richyhill said
Great little car, and love the webasto!
Massbad69 said
Cracking wee motor and the roof is cool as![]()
I love the Webasto, makes it so much nicer to drive in the sun! It doesn't cause any wind noise either
When taking the bolts for the pump out, every bolt snapped in the housing. I found a new housing on VW Heritage, which came with a pump and set off changing it. It's a bit of a nightmare taking the alternator bracket off because 2 of the bolts are hidden under the diesel pump. I managed to do it without having to take the diesel pump off as well
Everything back together (Nearly!)
The drive shaft bolts were probably one of the hardest bits to get off, as they all were pretty stuck in there and the heads kept rounding off. After a bit of persuasion with a hammer though we managed to get them out!
It was quite an easy job after that really though, just a matter of unplugging things and un doing a few bolts. I was surprised at how little electrics were actually there!
We both made the decision that it was going to be easier to lift the car over the engine, but after finding out the jack was just a little off raising it up high enough I had to try and find one that would. I made a few phone calls, and it turns out that my cousin has a proper big jack that can lift over 2.5 foot. It was perfect for the job.
and me standing like a lemmon next to the car
Its now got an empty bay, that needs to be cleaned
And I like how it sits on the wheels at the back now (i know im cheating a little bit with it sitting part way up a hill!)
Good work, it should be quite nippy with that TD in there
Hairyarse said
That's a mean looking rear stance!![]()
Good work, it should be quite nippy with that TD in there![]()
Thanks buddy, I'll have to roll the arches a little bit as they are scraping quite a lot
I'm hoping that it's a little bit better with the TD in. I've heard some good feedback about the lump but never had to deal with one in the past! Fingers crossed though!
I took the wiring loom for the petrol engine out today, and luckily the loom for the TD will plug straight in
Curious on how you approached the fuel tank though. I had the same issue but didn't remove the tank. Just lots of flushing of the system … it worked but at great cost in time and money :/
Check out my Chrome Bumper project - http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=chat%2Fgeneral-chat_3%2Funtitled_216
Retro Specification said
I used to have a GX so fell in love with this as soon as I saw it. It looks lovely!
I lifted the back up and dropped the rear beam off. It took a little time to get everything apart, but it probably works out a lot quicker flushing the tank with it out than with it in, and probably works out a lot better.
had to change the fuel filler neck as it was past the point of usefulness. I will have to take it all apart again as the tank was on its way out anyway, and I didnt have the money for a new one. It will probably be better to do it now anyway as I'm changing the fuel type.
Travis
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
allana13 said
Awesome man…. so what's the plan on the diesel conversion
Well, I was going to clean the bay and then put the diesel in to get it going, but I'm looking at another Mk1 as a daily now so I'm going to spend a little more time on the bay cleaning and moving bits about before getting the diesel in.
browner01 said
such a cool car![]()
Thanks Man
Ice2812 said
Looking good![]()
Thank you, got a few bits to be getting on with now that the weather is getting a little bit better
They started off like this
and started coming up really well when I got started
Comparing them against each other haha!
And a trial on the car
They havent come up perfectly, but they are a hell of a lot better now than they were before! Now just to do the other 3
