MK1 Golf GTI 2.0 TFSI Edition 30 p12 (was 2008cc R1 bike carbs)
1983 Lhasa Green MK1 Golf GTI
pazwaa said
Would definitely seem like the right hand side is too long. Or they've sent you the wrong piece??
Annoying when standard parts that should fit, dont!!![]()
Matt
Yup. The tube has all the correct part no.s on etc , anyway email has been sent to Custom Cages for confirmation. Dremel on standby!!
Firstly the plastic cover on interior light was so brittle it fell into lots of bits when removing from the headlining.
The corner of the left hand side foot well has a small rust hole
and the heater matrix is now leaking
Matt
I received a reply from CC today confirming that the right hand side just needs cutting down, once the left hand side has been fitted.
pazwaa said
Strange how you have to cut that piece to suit, would think they could provide it at the right length like the rest. But at least you can crack on now![]()
That was an error on there part, but I guess it's better being to long than too short
Rear turrets cleaned in preparation for mounting plates:
and minor surgery on the dashboard panel to trial fit the A pillars
The plan with the roll cage is the refit all the original interior afterwards, my take on what VW would have done if they did a clubsport MK1 Golf GTI
And secondly and more importantly I can no longer shut the doors unfortunately with the original door cards fitted!
Anyone that has done any welding will know how much heat can spread across panels that you are welding, so can be very easy to overheat the metal and distort the panel, which is not a good thing!
However, there's a great solution to this and that is to use Cold Front, simply place around the welding area and it creates a barrier and stops any heat from spreading. Very clever stuff.
So main door bars on both sides now welded in, as well as the main four point hoop, front screen bar and A pillars.
The above picture is of the door bar prior to using straps to pull the A pillars inwards off the brackets, allowing access to the back of the bars so that you can complete the welding right around the tubing.
Rear diagonal profiled ready to weld.
scottyr1 said
Great work!
Thanks! Slow progress but it's getting there..
Daz
Dazzlin34 said
Very nice work, very inspiring.
Daz
Thanks!
The recent work seems to have taken ages. Hopefully I'll be able to get it back together in the next week or to.
Gooly said
I love reading work like this. And it's Lhasa!!
Thanks for that. Hopefully I'll have some more updates at the weekend.
gelstharp said
cage looks sick great job
I've just got the rear harness tubes to install, but need to ensure they line up within 15Deg's of the seats.
Shiny new heater matrix and new hoses (just as a precautionary measure as these have been on the car since new).
Literally took no more than 15 minutes to drain the coolant, disconnect the hoses from the matrix, remove the old matrix….
..cut down the new hoses (not quite direct replacement
Jobs a good 'un.
ARRG Time: This was the *FIRST* time since the car left VW that the windscreen has been removed from the car, which is needed to fit the gussets, unfortunately after removal and inspection of the surface rust I've now got some more bodywork to do
