Jamiegolf's mk1 tintop resto
(In Topic #157050)
Plans are to sort the rot in the shell, wings, rear panel, front panel, slight bit around the screen, rear arches, spare wheel well.
im planning on fitting a polo openair electric sunroof, lowered, banded steels, baby blue paint, small chrome bumpers, possibly a roof rack, single headlight chrome grill.
basically euro spec, the last one I build I regret selling it to this day, this one is guna be better…….
Last edit: by jamiegolf
Mk1 Jetta (Jessie) build thread here
View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
T25 westfalia camper, 2.2 Subaru powered
vw touran 1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck……. www.jsgarageaberystwyth.co.uk
Smudger
List so far is
Wings (looking for drivers, found passenger)
Rear panel ( complete )
Front panel ( complete )
Rear arches repair panels (have passenger looking for drivers)
Fuel filler repair( found)
Lower windscreen corner driver side (found)
drivers wing and drivers rear arch to get, guna replace the inner arch lips too as there not in perfect condition, front panel is also on the to buy list, still undecided weather to repair the fuel tank filler recess or to smooth it off and relocate it into the boot??
Hairyarse said
New stuff, always good to get new stuff
+1. Great when the postie arrives with MK1 parts
Onwards and upwards mate
Few pics of today's progress
Engine ready to come out
The loom ready to be sent off and modified
Engine will be out by tomorrow night, need to give it a good clean, strip it too bare block and paint it, it has a small oil leak from the plug for the injector wiring, nothing a new O ring won't fix, will be ordering my conversion engine and gbox mounts soon, still undecided if I'm going to keep the 6 speed or change to a 5 speed, 5 speed would be much easier for speedo cable and driveshafts, the 6 speed will be custom shafts and some way of running the speedo…..
As for the gearbox depends on what you are going to be using the car for really and what ratios you want. 5 speed would be easier to do as you say but 6 speed is a bit different with this conversion
Good luck with it mate
Vw golf 1980 cab (girlfriend's)
Vw T25 1.9dg auto hi-top autohomes camper
Alfasud 1.5ti green cloverleaf
Alfa 155 2.0 16v
Alfa 155 Q4 lhd 1 for 13 in uk
Alfa 155 2.5td lhd the only 1 in uk
Alfa 155 2.0 16v
I thought 300 quid was a good price, I could do the loom myself, but just for the fact it will save me so much time I would rather spend the money and send it away, it also means I can concentrate on getting the bodywork sorted while not having to worry about the loom,smudger1980 said
£300 including an immob delete is money well spent mate IMO. At least you have peace of mind when it comes back.
I wanted the 6speed purely for the fact I had a speed in a mk1, but I will be happy with the 5 speed. Going to use the hydro clutch conversion setup from the caddy forum, run as much wiring and pipework hidden within the chassis as possible.
I going to be clearing my mums garage out this weekend, so I can get the car out of my storage container and into somewhere that I can work on it. I want to trial fit the engine and then remove it to crack on with the body incase indeed to modify anything
I traded the 6 speed box setup with a friend of mine who wanted to fit it into his mk4 non pd 110bhp tdi, suits me! I can now use cabby 100mm shafts, guna convert the steering column and run hydro clutch, I've heard horror stories of ppl using the seat conversion thing and it gives a heavy and stiff clutch and even more of a risk of it ripping the cable into the bulkhead! Mean a cleaner look in the engine bay too! Will post some pics once its all clean and painted. Oh and I'm still collecting panels!
