Golf GL
![joeyvw in the usergroup ‘Local’ joeyvw in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Golf GL
![](https://uploads.tapatalk-cdn.com/20201111/1c539a318968e1116ce9c37bef938ffa.jpg)
![](https://uploads.tapatalk-cdn.com/20201111/7cbf8bdc547ceefc2d9166a9242807b7.jpg)
![](https://uploads.tapatalk-cdn.com/20201111/ec0240035439eb59c76a9dd88627a4bb.jpg)
![](https://uploads.tapatalk-cdn.com/20201111/ed079424d919ff76ca26017a7a4146ec.jpg)
Golf GL
![](https://uploads.tapatalk-cdn.com/20201118/d190fd86963751f77fd9e8b4f6488cd1.jpg)
![](https://uploads.tapatalk-cdn.com/20201118/1decb6183e7e170627b0b769feda72a4.jpg)
![](https://uploads.tapatalk-cdn.com/20201118/75a3ed0920aa931cbc420e4b51d8f811.jpg)
![](https://uploads.tapatalk-cdn.com/20201118/4d7c3898e06c161036e7c02554d146fe.jpg)
![](https://uploads.tapatalk-cdn.com/20201118/5509f144fa5c38ad11c04a03d26f4c15.jpg)
Sent from my SM-A515F using Tapatalk
Golf GL
No tabs on the poverty spec model so had to make two custom brackets to mount the housing. I did try to use and existing mount but as you can see it was hitting the return inlet.
Also learned that the inlet and outlets on the vw heritage tanks sits alot closer together so space is alot tighter and as its gravity fed its alot harder to get it to run parallel.
I'll be running a 044 bosch fuel pump with AN-6 lines. Just have to other the torques fittings to plumb it all up now.
![](https://uploads.tapatalk-cdn.com/20201215/326ef55ec8d44f5e21fed8ad0db863d5.jpg)
![](https://uploads.tapatalk-cdn.com/20201215/8e6ddc59bcd4c6d06661cddf05fa7e33.jpg)
![](https://uploads.tapatalk-cdn.com/20201215/0faadadb3e0499b27e6a02982505ae3f.jpg)
![](https://uploads.tapatalk-cdn.com/20201215/e473239ae32e474cd64c957de60d657c.jpg)
![](https://uploads.tapatalk-cdn.com/20201215/beb86c71085d4cdaa0471494a3fa2dce.jpg)
![](https://uploads.tapatalk-cdn.com/20201215/92a70f210d7c35d76f06028608760c9c.jpg)
![](https://uploads.tapatalk-cdn.com/20201215/ae1fefd1dc8ff45ab5b13262c61d6b2b.jpg)
![](https://uploads.tapatalk-cdn.com/20201215/661e7cc3d2a6f4f997c9628010ff3b13.jpg)
Golf GL
![](https://uploads.tapatalk-cdn.com/20201215/ef2ca5b47cb837e5f0d9617c8674a584.jpg)
![](https://uploads.tapatalk-cdn.com/20201215/9ffab815e269c1d919a016049b080d86.jpg)
![](https://uploads.tapatalk-cdn.com/20201215/1785e65173c481bcbe76781d60e412a2.jpg)
![](https://uploads.tapatalk-cdn.com/20201215/2bc7032cb65c7d79cddc1cc3b0a3f9a8.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Image1512298769783.jpg)
![MarkkGardner in the usergroup ‘Paid Member’ MarkkGardner in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![MarkkGardner in the usergroup ‘Local’ MarkkGardner in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![plurker in the usergroup ‘Local’ plurker in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![:cool:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cool.png)
![](https://live.staticflickr.com/3066/2903598853_7c8c217801_o.jpg)
'83
Golf 1.5 GX - weekender - in pics: 1983 Mk 1 Golf GX - a set on Flickr
'88 T25 camper 2.1 - in pics: Gina the van's renovation - a set on Flickr
Re:
It's a lot of work but I think it's necessary on any mk1 nowadays to keep them maintained. Is yours a GTI?MarkkGardner said
Cracking progress mate! i remember when this car came up for sale 4 years ago i did think of getting it, I'm currently doing the underside on mine too!
Re:
Hi Plurker, this is great to see, thanks for the information and pictures. Mk1 looked very straight when it was in your pocession. I managed to track down the last owner in the UK before it came oversees go got a good bit of history from him and I still have the original bill of sale which is great to have.plurker said
So nice to see this back on the road; you've done a top job there!! I owned XPM 566Y for a year or so, in London back in 2008 - when it looked completely stock. I bought it for £250, did some basics, then sold it to a workmate for £800. Then it went off MOT register a couple of years after, so I figured he'd fcked it. I moved on from Mk1s, cause they got too small as a family car (got classic Saab900 now), but do miss them!
www.flickr.com/photos/piersmason/albums/72157607625754418
The fella I bought it off in Northern Ireland took it as a trade in and had no interest in vw's and knew nothing about the history either so it was a bit of a gamble but looks to have paid off.
Slowly getting there with it and hoping to have it on the road this summer if all goes well.
Golf GL
![](https://uploads.tapatalk-cdn.com/20210114/507ea6aa71152084103156cff5b82935.jpg)
![](https://uploads.tapatalk-cdn.com/20210114/4361561e73ec3d07551774bf4c743d30.jpg)
![](https://uploads.tapatalk-cdn.com/20210114/c6857a4d10cd2611543dc67a1158868a.jpg)
![](https://uploads.tapatalk-cdn.com/20210114/b8dd93e0f98cdccd53c035c20e34a0f3.jpg)
Golf GL
![](https://emoji.tapatalk-cdn.com/emoji23.png)
![](https://uploads.tapatalk-cdn.com/20210114/74e9eb912074fb6e1c21782461b0a972.jpg)
![](https://uploads.tapatalk-cdn.com/20210114/eb2b9f695588b575574bb2dd587a4841.jpg)
![](https://uploads.tapatalk-cdn.com/20210114/0b0bbb64009cc40268f45b83ad7b8f8c.jpg)
![](https://uploads.tapatalk-cdn.com/20210114/10e439a0c35db1d20a14c9db0b174588.jpg)
![](https://uploads.tapatalk-cdn.com/20210114/d2c10e6cea9819264195c8b37bd88db9.jpg)
![](https://uploads.tapatalk-cdn.com/20210114/b571b70cd90bdc3b7cc35cdab53b3b2d.jpg)
Golf GL
I used L041 2k paint with a 2:1 ratio and 10% base thinner. It's important to make sure the circulated air is warm with good ventilation. When applying coats go slowly to wet the surface. Allow 10-15 min in between coats. Depending on what you want you can go for 2-3 coats.
![](https://uploads.tapatalk-cdn.com/20210114/226fe17c127c4cb26c3fb5b5bfaeebd0.jpg)
![](https://uploads.tapatalk-cdn.com/20210114/e157051557ef071f2f7ef7718f5822e7.jpg)
![](https://uploads.tapatalk-cdn.com/20210114/c5d45808ee905ee4933b0f3f84503cd2.jpg)
![satans_creation in the usergroup ‘Old timer’ satans_creation in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Great job so far, keep it going
love seeing someone doing good work. Might motivate me to finish mine
Re:
Thanks a million, appreciate it. Covid and Brexit have really started to slow things down though but doing what I can for now.satans_creation said
Mirror mirror on the the wall who has the shiniest engine bay of them all?
Golf GL
![](https://uploads.tapatalk-cdn.com/20210215/784b4bfab2b21fdf121508fe9a0feb7d.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/86452e6fa26b990c94f7665c34efc14d.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/33eefe50296ca6b3800da84b0bf30452.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/0c502ea60c9a6fefefe22a72dea62c03.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/61d395637513e1888566aefcbb31e7ea.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/82326fa107fda36e05f5e863a7b4453b.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/c421926ebd944c9d9399b7718b1cd12b.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/fce8b47e31d599a9f2d937ca01f4c871.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/e79da5aaffe87bb88a51c2c231426772.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/543b6dac0727c50e5bd9a4ad410c0039.jpg)
Golf GL
Tried to salvage them but it was a loosing battle. Going to leave it into the machine to be redrilled and rethreaded.
Today's lesson: Just buy your hardware from Volkswagen directly.
I'll be working on getting the engine bay sprayed to rebuild some confidence of anyone is looking for me
![](https://emoji.tapatalk-cdn.com/emoji2357.png)
![](https://uploads.tapatalk-cdn.com/20210215/64ef5401a28a4b03998c362b1ea4bb89.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/0c3b6beeb31a4c1af2e11a1ecf9dd338.jpg)
Golf GL
Got a few parts painted and started to rebuild the block.
![](https://uploads.tapatalk-cdn.com/20210215/e2718eb2a67d4721d0f5f71ecba29bdb.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/b39f9eb8570ff10852bd548ba7086e92.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/89ce39698ae45022bc2125f2d4d1e18f.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/23d6440bb38b43b00e6d927f703ee80a.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/2da0e65bc53f67b49c6972dd01511a45.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/cbc13275c4225ab42ea71d79bebae353.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/3da6eb207cd4b7439a06867e1ec53067.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/4a8fc3f8c1a497181acba4952ac15d7e.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/a54162c450821e8ee6cb947d573b9506.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/49e0cd26cc6974300013b25bcaea6963.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/37ec7c903aa92f405b45c2c73d09ba4a.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/d9a6d143c298ff7fa8d90085784fb54b.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/4570c4118d0e9771a748e40227117f97.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/80afb4a8985adb685252a6a765a732bb.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/2816e765d7f54541049648ff1f0d5aa5.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/727e2ca5fc0090f1baacfa6800dd1abe.jpg)
Golf GL
Currently waiting on stainless steel engine bolt kit for final assembly.
![](https://uploads.tapatalk-cdn.com/20210215/5ac1554bc4215aef18a0ea84d6810484.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/5fe225e9c9f80f16619058f25b1dcdc2.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/27355093c12a967398ad839af83b06ae.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/3a90392b9fcf5b4af1322b1e02794beb.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/f86d4767dd6db59afd17d8194547a346.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/4e37258843cf2f4957243632a4a8477d.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/22e5f6bb4af69abeadd69ca843e7ee5a.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/c8c8ec92117266cdd0206d1dfe7578c5.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/bda92806faaafb82f479355f63241aa3.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/f93d2a3877fe96ce3286c9fff1801b88.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/c337c97e9d0ea61515c2d596b87ea790.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/c5139a416f8c096628f1dbda757879b5.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/d6cf45f688fdb68761a02d5a82a14a8b.jpg)
![](https://uploads.tapatalk-cdn.com/20210215/b38dd9c4c7d137f0708639fae27dc12b.jpg)
Golf GL
![](https://emoji.tapatalk-cdn.com/emoji16.png)
Work to the interior, fully painted and soundproofed, very happy how this turned out.
![](https://uploads.tapatalk-cdn.com/20210802/b967644469eb0ef363a96fcf64de152c.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/8ef5ce99a5b21bec277af06d622b3c74.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/1c2409014f44f24f14350b1beb9dc7a4.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/8d7ce326ec51474a40dadf3d10de6a09.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/00a5b1d35e542e881be361b0d245f5b0.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/5280f85e7db5bfb56425d68b0f06e519.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/5534685d8eab8376142da777974c8c15.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/48dd97df98cbcd021f970491815558dd.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/393493eecd43af7a79a73b3a2868b5ba.jpg)
Golf GL
![](https://uploads.tapatalk-cdn.com/20210802/969b39b71c047d0fb5b03b4985765a2c.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/234693ae7f0e9d9b5298f5973347880b.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/94938cffa3c88d1e9f8e72f96f816ed3.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/c6b4a7e23876c2a3679a680dd899b475.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/24919d3f4ead970f31a200890010620d.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/12337dc719ac1465e1f7332eaa54a0f7.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/1d365ca30d71cb55330dc116afbebcfc.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/2370ec24006d57eda0f62a4d33545101.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/dba7934dc360eb677ffbdf0c4443edb2.jpg)
Golf GL
![](https://uploads.tapatalk-cdn.com/20210802/2aa7161ce6c2942d874362830e2aae42.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/180b573d311450e884a851c9b09e5719.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/f58f8a67d1b229eaa6db1fc1f267d240.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/7535d9941f4edb7d5c8de44f05a5da53.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/999f9e3deb376b133ad1e51330ecdaf7.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/2326f0b8b28a0016055865905e27e90e.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/abb6a19e309fdf5a4a8acec2cb7178eb.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/c084efa156b040aacd91967ec972d2af.jpg)
![](https://uploads.tapatalk-cdn.com/20210802/0b6aa37f30e85dfe54bf737fc2d521dc.jpg)
