Buddy MK1
(In Topic #165792)
1983 Pirelli Edition
I started a couple of threads on other forums so thought I would copy my progress so far over to here.
I use to own a mk4 golf gti which I built up to this stage:
The mk4 was a great daily and served me well for a good few years but I felt I had taken it as far as I wanted to so stripped it for parts and purchased a new daily and a new project.
The new project is a 1983 mk1. It came with a 16V lump in it, mk2 leathers and some banded steels. I made the trip down from Kent to Bridgewater to pick it up and the drive home was brilliant. Drove well and sounded great.
1983 Pirelli Edition - http://vwgolfmk1.org.uk/forum/index.php?page=topicview&type=view&id=165792
The plastic backs were pretty beaten up so I pulled them apart and retrimmed them in a suede/ alcantara material. I think the result will help to make them look more at home and not too put of place. It certainly helps to date them slightly.
I initially didnt cover the airbags but after refitting them it was obviously that they would need to be covered aswell
The base panels will also be trimmed once I find some spare time.
As the bay was empty it would have been rude to just put the 1.8T in there and not tidy it up a little so out came the battery tray, off came the brake servo, MC and balance bar, off came all the seem sealer, and all the unwanted holes are being welded up. Im new to a lot of this kind of work so its taken me quite a bit longer that it would most.
In between working on the bay and interior, I started to tidy up the new engine. All unwanted items were stripped off, 16V tensioner, new waterpump, cambelt, custom engine mount, and a lick of paint.
1.8 non turbo cam cover
New carpets
New headliner Downpipe flange etc
Good luck getting her finished off.
Smudger
Matt
Scott - not that I know of but it may well have been. I found it through eBay
i want to do the same with the crackle paint on my block- what did you use to do it ? and also it looks like you pianted it with normal paint first then did the crackle ?
Design Manager
2018 Up! GTi 1.0 TSI
2015 Mk7 Golf R 2.0 TSI 4motion DSG
2011 Caddy Maxi Kombi 1.6 TDi
1982 Mk1 Golf GTi 3 Door 1.8t - Build Thread
Marketing Manager
Can't wait to see this finished
1973 BMW 3.0CS "Helga"
1981 VW Golf GTi "Agolf"
1986 Ford Escort RS Turbo S2
1987 BMW M535i - 'Klaus'
Instagram: @ahmet_e9
Had a good weekend on the car. Finished stripping the underside back to bare metal. one of my rear beam studs snapped when removing it so I cut it down, drilled it out and dropped a new bolt in from the top.
Nice job
Matt
I managed to get the rear arb on the rear beam last night. The arb brackets are such a pig to fit but I got there in the end. They went on a little wonky but a bench vice straightened things out.
I am blown away by your skills!
Oh I nearly forgot, a very warm welcome to the Club.
