Baby Blue
(In Topic #210618)
Old carb 1.8 taken out & now rescueing another car somewhere. Got the 1.8t & 02J in on Epytec mounts after getting a new cambelt kit, water pump & spaced out 16v tensioner. Also popped in a 9" servo yesterday
Now have to fit a SMF & loads of service parts including bushes, wishbones, bearings & brakes (gone for G60 280mm at front thanks to a member here). I do have mk4 rear calipers but none of the other conversion bits needed so will see how the drums do first after renewing all the parts
Found a big piece of the jigsaw this week & got a Qpeng downpipe (note: they no longer make or sell this for the mk1 so unless you make your own downpipe or go down the K04 Trackslag route then you're stuffed at the moment). Just can't justify the extra £2k+ outlay for a remapped Bam K04 225 set-up to get just an extra 50bhp & then need lsd e.t.c! 220'ish bhp after a remap is good enough for me with a K03S, had that in a mk2 revo mapped golf last year
Normally you just have to take them a bit and they scan it.
Can't beat a bit of a jigsaw! at least there's plenty of info on the 1.8t swap. Looks like it fits ok though!
Good luck with it
Matt
Struggling with how to wire in main fuel pump & lift-pump which is slowing me down something rotten lol.
Last edit: by Cushti
But as ian said, did she start?
Matt
Just ordered a new filler neck & hose from Classic so will try again then
Matt
Baby Blue
Baby Blue
Thanks mate!! I thought that but once there on defo looks better in my opinion..Cushti said
Hopefully mine will look as good as yours one day. Gives me motivation. Looks great with the bumpers on but I'm still undecided on that
1. The stock seating position is far too high for me, I'm 6'3, and this lowers the seating position by about two inches
2. A common problem mentioned about the 02J mounted underneath is the gearknob feels too low for stock seat height, this sorts this problem out as well
3. I've fitted them before to a mk2 1.8t (was easier going into the mk2 though as I could keep the rail)
4. The grey/black design should go with the grey/black door cards & new black carpet
5. They're light, comfy & hold you in position going round corners at speed
6. Last but not least I got them for £40 & should clean up well!
Everything in position for the hydraulic clutch conversion. Just need to find someone to weld the bracket onto the column now.
I remember reading somewhere that the cabrio has the floorpan of a rocco, not a tintop. Anyone know if I can use the rear cage of a rocco in a cabrio then and if yes is it from a mk1 or mk2 rocco? Perhaps the existing cabrio roof bar would foul this cage. This might be best as a question in the Technical forum.
After a minor no power issue, thanks Rubjonny for some forum advice, I get a little nervous going to start the 31 year old cabby up for the first time in two years, having never run it before & after doing a 1.8t conversion, yikes. Drum roll & my god she starts up first time without hesitation & sounds awesome. Well for about a second anyway before she cuts out lol. But she's alive!
It could be one of a hundred things but my main suspect is I've been sold a duff ecu which was supposed to have been remapped with the immobiliser deleted so will have to send it off somewhere to be checked. Hey ho, all part of the fun & getting so close now
Heater leaking when filled up with fresh anti-freeze lol. Fitted new one. Then switched fan on, worked for a few seconds but kept blowing fuses. Motor almost seized. Fitted new one. Pleasantly surprised that both jobs were quite easy. Aftermarket steering wheel fitted.
Forgot about rear fog light as it was missing from the car when I got it. But I'm not fitting a solo unit down low. Due to the reverse light switch issue anyway with an 02J I just decided to swap over the rear fog light switch wiring to the reverse bulb in the rear lamps & changed the bulb to red
Stock G60s now fitted instead. Put 15mm spacers on the back as I don't like them sitting so far in.
Off to paint shortly so should be ready just in time for late Spring!
I did the same on mine, tidies the back up no end
Current rides:
1. Previous owner had put early front wings on so it has no side repeaters (mine is '87, this is only ok on '86 & earlier). Will have to buy them, drill holes in the wings & splice into fronts
2. Fog light illumination bulb not working in the switch, the switch itself works
These later fog light switches are like rocking horse sh*t. I can't find a post'84 front/rear combo switch for sale - only VWH can seem to order them in 8-12 weeks so no free re-test if I have to wait this long. If anyone has one please let me know!
