AT LAST! Hairys Resto!!
(In Topic #90838)
Spent all of last weekend sorting the garage out, only had a few hours on it today but started to strip it anyway.
One MK1 Campaign ready and waiting for resto!
Dismantling has begun!
Rear corner came off in my hand!
Seat belt mounts dont look too bad
Inner arches don't look too bad either (Keeping my fingers crossed!)
Wont get to touch it again until next weekend - will get Saturday on the car then on hols for a week :cry: Maybe I'll start welding next weekend?
In the meantime, got copious amounts of WD40 soaking in to the rear axle mounts - really hope they come off ok - they don't look too good!
I'm still unsure how best to support the car to take the rear axle off - may try and make up box section frame to go in the rear bumper mounts - otherwise scaffold plank or similar with axle props - this ok under the floor?
Finally, anyone recognise these?
Haven't checked myself yet but guessing MK2? Although I'm told the front discs are off an early Passat - period upgrade!
Hope to keep on this and make some good progress - will keep you all posted :wink:
Andy 8)
1982 Non Sunroof Black 1600 GTI
2003 MKIV Golf PD150 GT TDI
foxymk1 said
looking good hairy, wats under them archs?
Do you mean the rust, the WD40 or the Bilsteins?
crazyquiff said
Hairy's started
Hip Hip Horay
Hip Hip Horay
Hip Hip Horay
:wink:
I know, I know - about time!
I'll be in touch shortly for some bits - namely the braided hoses from/to accumulator! :wink: Will give you a shout after my hols next week I guess?
rust lol,
But I will look forward to the journey with you…………………..
Sorry that sounds tacky
Looks a good project, another mk1 saved
www.cw-se.com
"Video et taceo"
"Video et taceo"
They held for a couple of months no probs, and didn't get in the way of the resto either.
Good luck with it
Rich
Good luck! :y:
Thnx for the kind words. Will be a couple of weeks before any update :cry: Was hoping to get the welder out today but been away with work all week - got back 10pm last night - now got 3 hours to pack before going on hols for a week!!
Going to Portugal for a week but seriously contemplated staying at home to work on the MK1 - how sad am I!!
I can't wait to start welding new metal in 8)
Watch this space….
Life Member
I've got the car jacked back up (forgot to take the doors off before putting in my narrow garage! ops: ) Rear beam mounting nuts/studs are very corroded. Given second dousing with WD40 tonight but really dont think will make any difference.
Was thinking of getting tap/die set and trying to re-cut thread so smooth - I think its M10, anyone know? :dontknow: Even if I can get access to do this, not idea how to get the nuts off. I'll do a search but any advice appreciated! :wink:
Want to get the beam off, tank out and start welding this weekend! 8)
failing that if they shear off im sure you can reweld some captive nuts back in there :wink:
Life Member
When you mention the rear flexi, what are you refering to??
My beam studs looked pretty bad and took a bit of cleaning up. I tried a nut splitter, but found it kept wanting to pull at angle - also got a bit concerned about damaging the tread. In the end managed to undo all four nuts. A good extension bar is important as you get some decent leverage and feel for what's going on. Also if the nuts start turning, it's importnat to not move to much too quickly and keep soaking with WD40 prevent to minimise chances of shearing off.
Good luck :wink:
1983 1100 C
1983 1100 C
