82' tintop mini resto/winter work
(In Topic #193022)
She's an 82' tintop with a polo gt engine and 5 speed box.
So i started off a few weeks ago, around the beginning of december 2014. Many of you who attend the shows might of seen it about, i just plan on sorting out as much of the rust/rot as possible, prepping the car for its respray and also painting/undersealing the underneath and other bits and bobs too a good standard!
Iv never done anything like this before, my first time even properly working on a car (im 19), but hey, everyones got to start somewhere and iv enjoyed it so far!
Iv had problems with uploading pictures on this site before so hopefully things will all go smoothly with the uploading.
I'll try and update things as much as possible. I dont get a great amount of time due to having a week day job (which also envolves being on 24 hour callout for a week every couple of weeks) I fix potholes
Anyway i'll stop rambling on and try and get some piccys uploaded!
Any help with things would be great, need as much help and advise as i can get!
Now some pictures of when i started the strip down. I didnt take as many pictures as i would of (didnt think i'd be doing this thread back then) plus i was too excited to get cracking to take photos
I swapped over my schmidt th lines and put on the crappy teledials while work commences.
Started the strip down, wings off, headlights off, grill and other little bits off, also discovering rust
The passenger side sill is alot worse then i thought after poking about with a screwdriver, turns out about 3 quarters of the sill will have to be replaced. The inner sill looks solid from what i can see so im safe with that. Only thing is the strip along the bottom as you can see iv pretty much managed to snap that off the whole way along. Now i need some help, is that the outer sill and inner sill joined or is that 3 layers or just the outer sill edge?? what i snapped off seems very thick to be one layer of metal??
Anyway so i started doing me first ever bit of body fillering. I started smoothing off the rear wiper and washer holes. Didnt turn out too bad, though i did in the end go over it again and re do it after several times.
I also took the inner wings down to bare metal just to see what they were like as the current underseal was so thick i couldent tell if there was anything wrong underneath it all! so using a flap wheel on the angle grinder and a dremel in the harder to reach areas i got it all down to bare metal. what was underneath was too bad! i found a few little bits of surface rust, so i took that down with a wire wheel etc and treated it with a rust killer.
Take so much longer having to use a generator and keep getting the car out all the time!!
Miranda the 1982 manilla Green 5-door tintop
Cleaned up and treated what i could treat and left what would need cutting out and replacing!
I have this to tackle with!! Part of the inner wing mount and above the turret to replace! im suspecting that this rot/rust spreads all over the turret but i really hope not!!
I knew i'd have the windscreen corners to sort out but oh my, i didnt think i'd have to replace the inner wing just below it! i'll have to somehow get my head around how to do it! Here's a picture of each side..
Next up i took a look at the must worrying bit.. (though the sill is just as worrying!) The rear seatbelt mounting point. a few months ago en route to a show, i heard something rattling from the rear, turns out my rear seatbelt was no longer connected
Really not good, had a good look inside with a torch and i can see it's spread along the joint where the tub meets the inner part you see from inside the boot (near the rear washer bottle mounting point) I dont know how much of the tub has gone around it yet but im hoping not a lot!!!
Hidden under loads of filler!!
While i was depressed about the extent of the rust/rot i started p400 sanding the rear of the car for its respray, making it loverly and smooth and keyed in.
I next cut out a little patch in the spare wheel well. Nervous to do my first ever bit of welding after practising a little.
I found out a bit problem with my welder, which i should have looked into before i set out to buy a welder. I stupidly bought a gassless mig welder, cheaper than cheap sealey 100 amp. well i will now be investing in a gas mig welder which adjusts down to around 30amps seen as im welding thin sheet metal. I know how bad gassless ones are so dont tell me how stupid i am, i know! all part of the learning curve i guess!
Anyway before i realised all this i did do the patch in the spare wheel well. this is how it looked half way through, not too bad for a first attempt!!
Thats all for now! Any help would be great!
Your car looks great in the first photos, but looks like the dreaded rust is lurking under the paint. You should maybe do a full strip down, find out how bad the rust is and where it is.
Look at meltdrummer's thread, he's changed pretty much everything on his shell with great success, a good guide on what needs doing
Your welding looks very good for a first timer, it's hard welding these cars as they're so thin steel, but your off to a flyer
Good luck with the project.
Matt
Jamie
RichardHall said
Looks really good, especially working in such cramped conditions. I can't work out if the colour is standard which it seems to be in the pictures when you are working on it, to the one with the Scirocco in the background when it looks like it's in the same Vioer Green?
Its manilla green, which is one of those colours that just changes shade in so many different lights.
mk1 Jamie said
Good work …Nice to see someone else young doing all the work themselves![]()
Jamie
Thanks!
My new mig welder arrived (took a while) which is why its been going slow, that and being on callout at work. But i got it all set up and got practising with it.
So the hole in the spare wheel well is finished… and i forgot to get a picture of it, so not picture of that!
I then started to crack on with the wing mount/turret which is what iv been doing all this weekend.
I cut out all the rot and fabb'd up a piece for the inner wing mount..
Then i tacked it in place and sprayed it with weldable zinc spray..
Next i fabb'd up a piece for the bit between the turret and the wing mount and tacked it in place then joined up the tack welds..
I then finished it all up and zinc sprayed it. I then grinded all the welds down and applyed some filler to just smooth things out etc etc.
Im yet to sand the filler smooth but this is how i left it tonight..
Im happy with what iv done so far, im going to try and make a start with the windscreen corners once iv finished this.
The bottom lip of the sill is the floor pan, inner sill and outer sill spot welded together which is why it is so thick
Will be watching this one
Morgie said
Brilliant start and top marks for doing it all yourself!
Thanks! oh god so i'll need to weld the floorpan, inner sill and outersill
matt
pazwaa said
nice job on the repairs![]()
matt
Thanks matt
Ad.
So i cut out both windscreen corners tonight, only to discover i am going to have to replace abit of the apiller on one side and both sides of the inner wings at the back plus the mount on the top of the inner wings (both sides) oh and a bit of the rain tray on both sides.
This isnt going to be easy and i have no pictures due to my phone dieing but it's not a nice site to see
I need to remove the dash before i do any more cutting or welding, i can see the loom and wireing through the holes, dont want to set the car on fire! I do however plan to get atleast one side finnished this week, even if i have to stay there untill 11pm again haha
Baggie82 said
Good work so far dudeLooks like your unearthing somebody's previous bodgery. Keep going , you'll get there !!
Ad.
tell me about it!! i cut out both windscreen corners tonight to find out it was held together with screws, cardboard..yes cardboard and filler
First up is the passenger side apiller which is the worst bit. I set out to remove the dashboard tonight but got sidetracked half way through haha. Good thing is i did get to see what it all looked like from the inside and to be honest, it's really not too bad! it hasnt spread far and it should be something i can fix and weld up
Any tips on welding here?? i havent seen any threads on it at all, but im most worried about a fire or damaging the fusebox or loom or setting fire to the sound deadening.
Over to the drivers side.. it has quite a nice size hole in the inner wing now
On the bad side of things that hole in the inner wing, i'v looked through from the inside and pulled the carpet up etc; ok it could be alot worse, alot more worse, so its not really that bad. It seems to be like that previous repair you can see below the hole wasnt sealed properly and waters got in etc and its started to eat its way up. God knows how i never had any water in the footwell or a wet carpet
Advise please on anything guys
Lovely colour that, will be nice when it's all done. Sanding filler - I hate that job! lol
Looks like you're getting stuck in well. A couple of comments if you don't mind them?
First off, I can understand if you want to do a windows in re-spray, although out is ideal (I assume that what you're doing) but take the rear lights off. It's so quick to, and will make finishing and painting the rear panel much easier.
(sorry if I've got the wrong end of the stick!
Second, good call on zinc priming the inner wings. I had an inner sill repair on mine sit for 5 years (
Good luck with the resto, looking forward to updates
